More storage
    More storage
    I have been wanting to do this for a while now. For those of us with a 22i that do not have a TAPS pump located under the seat to the left of the drivers seat in the walkway there is a good size empty space. With me adding some ballast bags this year I was looking for just a little more storage space.
    Now the stock non-removable seat bottom is removable and I have a little more storage space. I used some rubber block's (like on the other seat's)to hold the seat bottom in place and it works great. I will probobly line the space with carpet to make it look better and smooth out the edge.
    What years have the TAPS pump located 'under the seat to the left of the driver’s seat in the walkway'?
    Thanks!
      Whatever years have the hydraulic actuators. Mine is a '04 and it is electric. I think Tigé went back to the hydraulic in '05 and maybe some prior years also. '05 might be a mix.
        my 2000 20i has the hydraulic pump in front of the captain's seat.
          good idea
            I wouldn't worry much about smoothing it. I would find some edging and cover it. That is as smooth as some of the hidden factory cuts on my boat.
            http://www.wakeboatworld.com
            []) [] []V[] [])
              I was thinking about edging also.
                Mine has a cooler right there.
                  wonder why tige didnt put storage there originally?
                    You have a different model.
                    I have wondered that since I bought the boat.
