21 i ballast thoughts!
    I',m considering buying 45 lb rubber plates for ballast
    on my 21 i 07....8 rubber coated olyp plates in the back
    and four 45 in the middle.....
    I'm looking for advice on this matter.....THANKS!
    I used 100lbs dumbells last year.....not stable!
    Your Yard Is My Gym!
    Water Ballast.
    The sun never sets on a badass
      THat only like 500 lbs total?
      Are you concerned w/space?
      I would agree w/wannabe - go water i'd say tsunami pump and sacs.
      talk to domz06 on his set up i think he used to have his 21i dialed in for a sweet wake.
        I had considered going with dumbbells before as well, but I decided i didn't want the extra weight on the lift. If space is a concern, you could consider rebuilding your rear seat to get more space under it.
