Maybe some of you guys can help me out. I'm looking into buying a new 20i. I've got a '93 SLM 2000 and was wondering how the wake in the new 20i's would compare to the wakes of those put out by the older models (92-97)? I'm sure some of you folks have skied behind both and could help me out.
20i Slalom Wakes?
Although I have never skied behind it I do know that the hull is completely different. The 20i hull is built so that it can cross over from slalom to wakeboard. It has the ConvexV hull. Which means its a V shape and is also a convex shape. In combination with the TAPS the boat can change over from slalom to wakboard by just changing the running surface of the hull, just by adjusting the taps. It does not have the flat hull to it like your '93 probably does. Although Im sure its pretty good slalom boat (better then my 21i) Its not going tournament level. But if you are looking for a boat that you can have exceptional slalom wakes and pretty descent wakeboard and surf wakes, this would be a good boat for you.Common Sense is not so Common
20i slalom wakes
Originally posted by pklakeguy View PostMaybe some of you guys can help me out. I'm looking into buying a new 20i. I've got a '93 SLM 2000 and was wondering how the wake in the new 20i's would compare to the wakes of those put out by the older models (92-97)? I'm sure some of you folks have skied behind both and could help me out.
FYI - mine is for sale
http://www.flickr.com/photos/1172102...7601551979229/
http://richmond.craigslist.org/boa/436472441.html
Griff
griffgriffin@verizon.net
Originally posted by Griff View PostJamie Beauchesne skiing behind his 2006 20i.
http://www.youtube.com/watch?v=WSKV9J47ZNg
Originally posted by bfrank View PostI wonder how he has that set up?? The wake looks non-exhistant. He must have some tricks to get it that dialed in.
Picture of Rossi's 20i is at
http://www.waterskimag.com/article.jsp?ID=21015467
Griff
Originally posted by Griff View PostI have skied with Jamie and Chris Rossi, both have the same 2006 20i I have, listed above. We set TAPS to about 2. It really is a great ski wake.
Griff
The 2006 20i was also AWSA certtified for 3 event. The 2007 was not certified, I understand, because Tige didn't supply one for the test. Also the 2007 was not compatible with the current AWSA certified PerfectPass cruise control with the MarinePower engine and MIFI 5 Medallion guages. The boat and hull itself was exactly the same.
The 2005, 2006 and 2007s had the teak platform option. I upgraded mine with an additional piece of teak to protect the transome from skis and boards. I still have another piece of teak that is enough to make anotherone.
Here it is, if you missed it:
http://www.tigeowners.com/forum/showthread.php?t=4018
