As an owner of a 99 21i that lists at 94" beam and 2900lbs, how would its ski wake compare to the new 20i that is heavier and wider? I think my hull is a convex V but I am only 1 year into the whole tournament boat deal. mostly I get in it and turn the key and it starts and I am happy.
Midwest 20i
Hammer
Bolo I wish I could answer that for you buddy, but this 2008 20i is the first Tige' I've had first hand course time with and I'm really impressed. I had the chance to go straight to the factory and have them not only walk me through the set-up of the 20i for a tournament, but also follow it up with an on the water session at a private lake so I've seen it at it's best.
As the boat designs have evolved I know they have (for example) increased the overall rocker of some of the hulls like the Z1 versus a 20V. Similar size, same target audience, different boat entirely. If any of the dealers participate on this forum I'm certain they could tell you when the hulls changed and how.
thanks anyway. Its not like I'm going to sell this boat anyway but after spending some time reading on this site I'll definitely fiddle with the taps to see if I can make it softer if not smaller. Are there any dealers out there who can drop in a few lines of knowledge? Much appreciated.
Come on summer!!
Hammer
Originally posted by bolo View Postthanks anyway. Its not like I'm going to sell this boat anyway but after spending some time reading on this site I'll definitely fiddle with the taps to see if I can make it softer if not smaller. Are there any dealers out there who can drop in a few lines of knowledge? Much appreciated.
Come on summer!!
Cheers,
Bill
Hammer
"Toni's first event"
Well we put "Toni" the Tige' on the water to pull her first event yesterday. 6 and a half hours of constant passes split about half and half between slalom skiers (26-34mph) and wakeboarders running between 18 and 23mph. It was a big hit for the participants and a lot of fun for me proving one way or the other whether the hull would do what Tige' claims it will.
Verdict: It performed flawlessly. We spent and hour or so in open water making sure we had all the settings down. As it turned out my TAPS gauge doesn't drive all the way down so instead of 2.0-2.5 being ideal for slalom it ended up being 3.0-3.5
It was a lot of fun.Attached Files
Originally posted by Hammer View PostWell we put "Toni" the Tige' on the water to pull her first event yesterday. 6 and a half hours of constant passes split about half and half between slalom skiers (26-34mph) and wakeboarders running between 18 and 23mph. It was a big hit for the participants and a lot of fun for me proving one way or the other whether the hull would do what Tige' claims it will.
It was a lot of fun.a naked Tige without a tower.........
j/k, glad that everything worked out well for you. That is why we all like ours also.From what I have seen, the TAPS gauge is different on every boat that I have been on from Tige so far. But, it is alway fun to find out what setting works great.
Hammer
Originally posted by bfrank View PostWhat was the water temp?? Our main lake is still at a chilly 45 degrees.
Hammer
As far as the TAPS gauge goes I figured out why the numbers on the factory boat did not equal the numbers on this one. My gauge won't drive all the way down. That throws off my setting by a full number. Now that I know where slalom, trick and wakeboard settings are it is a much more manageable boat.
Originally posted by Hammer View PostYa she's topless for now, but there will be a monster tower on it before long.
Is that a USA themed boat? Looks very nice.
You should be able to get the taps fixed I would think? I is electric or Hydraulic?15 Escalade ESV-Black
08 RZ2-Blue
Hammer
Yes the boat was inspired by my dedication to this country. Old glory still takes my breath away.
There isn't anything wrong with the TAPS plate, it's the gauge. The plate goes all the way down, but the gauge stops before it hits the bottom of the gauge. It should be an easy fix.
I believe the TAPS II system is based on a traditional Bennett trip tab.
Hammer
Hammer
Hammer
