First time owner of 2000 22i. I've boated for a few years on the old man's crownline, but I have to say I think I bit-off more than I can chew. Any suggestions or hints would be greatly appreciated. I guess my first question is on the control panel, I have three switches, 1ACC, 2ACC, and 3ACC. What are they, and what do they do? Also the boat is great shape, but the carpet is pretty worn. Where could I get new carpet, and how much is does it typically cost. One last question for night. I have a wooden platform(teak or teek?) It looks pretty good, but could I sand it, and if I sand it, what do I put on it, to make it look sharp?
First time owner. Got a 2000 22i
The switches I cannot help you with, I have no suggestions for buying carpet for your boat, but they will ream you for, its going to be expensive, for custom made anyways.
Click here This should help you with you teak problems.
This thread may also help.
If you just want to sand it, but you can add some kind of teak oil.The sun never sets on a badass
Originally posted by fellad31 View PostI guess my first question is on the control panel, I have three switches, 1ACC, 2ACC, and 3ACC. What are they, and what do they do?Common Sense is not so Common
Originally posted by fellad31 View PostThanks for all your help. Looks like I have some sanding to do!Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
My ACC switch controls the radio and that's about it. It's possible it controls your 12v connections or courtesy lights (if you have them).
Carpet's more difficult. It's glued down. A marine upholstry guy will be able to do it, but I'd wait until winter when they're desperate for business.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
There is a ton of info on teak on this site and also on the Internet so you should not have any problems bringing it back to like new condition.
As far as the switches, like Zad said, turn them on and look/listen for stuff to come on ie shower, lights, radio, heater. They may not all be used.
Carpet........good luckLike Dog said, research now, fix over winter. Take pics when you do, we like to see projects
First time owner of 2000 22i. I've boated for a few years on the old man's crownline, but I have to say I think I bit-off more than I can chew.I never owned a ski boat until now either. Can't understand why now. Good luck and enjoy.
Dale
2000 21i Tige
and had a little water over the bow....just once. Thanks for the info, just alittle too late.I really thought I sunk it. Freaked me out. So I don't do that anymore. No riders upfront if I can help it.
Dale
2000 21i Tige
acc
My acc switches control courtesy lights throughout the boat.
Try hitting them after dark and see what happens.
You can also look under the dash to see if there are even any wires connected to the switches...if not, then they are not connected to anything obviously.Other than that, Mrs. Lincoln, how was the play?
