Hi there, I just bought a used Tige; 99 pre 2200iWT, and I am having problems with a leaky prop shaft. Anyone no how to replace the prop shaft seal, and what size of "waxie rope" to put in there. Obviously, I'm a newbie, with limited mechanicle experience. Is this a job that should be done by the shop? Any help would be apprecited. Thanks!!!
Prop shaft Seal
I am doing a writeup with photos of my PSS install. I also did the writeup on the regular rope style packing install. I should have that posted by Friday. I have had to keep retightening the GOR packing since I installed it to keep it "drip free" as they put it. It gets old pulling the cover panels and redoing it every other weekend, so I dropped the cash on the PSS shaft seal at skidim's recommendation.
Not 100% sure on your boat, but on mine; pull the rear seat and seatback, pull the motor cover off, there is a panel that can now be removed. You have super easy access to everything.http://www.wakeboatworld.com
[]) [] []V[] [])
