so here's what i'm doing this year on the 22i. supposedly this setup will work really well. in the past i've tried front weighted, rear weighted, and mid weighted. plus everything in between. i'm anxious to get out this week and see the wake.
finally got the weight down... i think?!?
yeah the bag upfront is a 750 so i figured i'd just add a little or let some out to tune as well as using taps. i didn't put it on there but if you take into consideration that my year model 22iR has a 49 gallon gas tank at the very back it plays a huge role in adding extra weight to the back. i generally top if off everytime out. good input though because my hull and yours aren't that much different just placement of motor weight basically.
Originally posted by typerider View Posti've been wanting to get rid of the 750 for two custom sacs that fit under the front seats. then i'd like to run a split hose setup to each of those so i can fill both at the same time with one pump.
With the 22i you wont be able to get that much weight under the bow cushions. you just have to have it in the walk way and deal with it like i do if you want enough weightEverything happens for a reason
i've done 40/60 before and it works pretty well. i was just going to try this out to see what happened. if i don't like it i'll just move some stuff around and make it work. but like i said earlier i always top off the tank and since its around 47-49 gallons i was curious to see if the 50/50 setup would work better. the 40/60 gets pretty washed out sometimes seems like too much in the back. we'll see what happens after i put the new steering cable in and take it out this weekend. i thought about that huge v shaped sac but i'm pretty sure it won't fit under the seats and i don't want it on the seats. the 750 sac works great, plus it sits about as high as the seats so it turns the bow into a lounge.
so finally took tried it
this is the 50/50 setup at 25-26mph. sweet spot is 70ft out. wakes weren't that big but they were stout and clean. shaped up to a little less than knee high (i'm 6'1"). i think it needs more weight to the rear for sure. will put up more pics next time out. 1st pic from 2-9-2008 with almost 2000lbs in. 2nd pic is a pic of me riding terribly and shot on 10-12-2007. as you can see the wake is much flatter and that was at a weak 65ft out. we only had like 300lbs in the back and 50lbs up front that day. for sure moving more weight to the back next time.
