2002 21i typeR
    2002 21i typeR
    I picked up a 2002 21i typeR a week ago and it needs a few things.
    I need help locating the blower as it does not work and I assume it is under a panel in the rear storage.
    None of the gauges illuminate when lights are turned on.
    Several hinges and struts are missing.
    I'm sure I will find more items that need addressed as time goes by.
    Thank you in advance for your help!
    Blower is under the panel in the rear storage. The fuel tank is under it as well. You will see it mounted to the transom if I recall correctly. Been a few years ;-)
    Blue wire is lights for the gauges. Sounds like you have a break in the first/start of that wire chain. They just jump from one to the next.
    Have fun with the struts. Will have to find someone with the same boat so they can look at the poundage.
    Oh Yeah!
