That's a good question. All I know is that it's Carburetor 8 cylinder (Inboard) with no drains for the hoses.
Winterizing engine
Originally posted by domslude View Posti'd love to have one. I have one for all of my cars, why can't they make them for boats?http://www.wakeboatworld.com
[]) [] []V[] [])
i refuse to take my boat to a dealer, in less it's warranty. I mean hello, boats are the last piece of toy I can work on. My f250, yeah right,my z? give me a break they are the most complicated piece of equipment in the world! It's hard enough changing the oil on my two rigs, let alone working on them. AT least boats you still can, for a while! I do all the work I can on my OWN!Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Still trying to figure out why you guys pull drain plugs.....they are there to pop out if it gets so cold the water starts to freeze. Mine will not come out unless they pop out as they are identical to a regular car blocks freeze plugs.....no way to pull them without a tool.
FYI I only have 4 large plugs too. MarinePower Sport Pac. I also have some type of drain bolt on the star side at the lower part of the block. I am pretty sure it's a drain plug.
I drain the manifolds and pull the impeller hoses. Doesn't get cold enough for much more.http://www.wakeboatworld.com
[]) [] []V[] [])
LOL, we're not talking about freeze plugs, but the pipe thread plugs in the block and petcock plugs in the manifolds.
by the way, freeze plugs, as they are called, are not there for that reason. The holes are there to remove the inner part of the engine block mold after the block is cast. They can and do pop out if a block freezes, but not always before the block cracks. That is why they are called "freeze plugs".Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostLOL, we're not talking about freeze plugs, but the pipe thread plugs in the block and petcock plugs in the manifolds.
And yes I am aware that is not their primary function. They are leftover holes from the casting process. The plugs are just a byproduct.http://www.wakeboatworld.com
[]) [] []V[] [])
