I have a GM Vortec 5.7 litre 340 hp 2005 (22ir) engine and i am winterizing it. The manual says you can just empty both exhaust manifold drain plugs (both sides) and the circulating pump hose and the knock sensor and drain all h2o completly, i also drained the water from the engine transmission cooler, a total of 10 drain ports. I wondered if I need to fill the engine back up with winterizer or can I just leave the plugs out during winter and be ok?
Also, how much winterizer does it takeif I put it into the engine? I was told I could just poor the winterizer into the raw water intake hose and crank the engine over until it spit out the back of the exhaust ports and that would distribute the winterizer where it needed to go. Anyone have any advice or recommendations? My boat will also be stored indoors in a non heated storage unit......Thanks L
