I have a 2008 model 21I with a Kicker KX700.5 amp and a KX350.4 amp driving 8 speakers. I appears I have lost the amp channels that drive the tower speakers. Wondering if anyone knows which amp drives these. If any one has had a similar experience and has suggestions it would be appreciated. Thanks.
Kicker sound system
The KX350.4 will be the tower amp. The RCA cables connected to it are likely connected to the head-unit's purple non-fade outputs. Are there any lights on the amp to indicate its got power and turned on? I would start by checking RCA cables to make sure they are seated. Next, I would swap some RCAs with the other amp and see if it plays or use a 3.5 x RCA cable from your phone/mp3 and go directly to the amp inputs.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
