Drain Fuel (Gas) on 2006 22i
    Hi all,
    My first post here. We have just imported a 2006 22i from Florida to Australia. I want to drain the fuel out and refill with fresh supply before I fire it up. Any pointers on the easiest way to do this?
    Thanks
    Most likely was shipped without fuel. However, get a squeeze bulb fuel line (outboard fuel tank) from local general store with 3/8" hose and at least 6' of hose, attach to the fuel tank fitting and hand pump until flow starts into whatever container OUTSIDE the boat until you're done.
