I recently purchased a 2002 22iR and I have a couple questions.
1). Is the Bilge always on? Meaning, if I leave to boat in water and for whatever reason the boat takes on water, will the Bilge automatically turn on when the water gets to a certain level? Or do I need to flip the dash switch on before covering the baot and leaving it?
2). The two seats in the rear of the boat (on either side on the step over) are loose, like someone tried to remove them. Is there a way to tighted them back down? My fear is someone will think they are removeable, and pull them off doing damage to the boat.
3). I removed the swim platform to install some Gator Grip. Unfortunately, I could not place the platform back on the boat without removing the screws in the center bracket. Two of us could not get the platform to seat in all 3 brackets. Once I removed the screws, the platform dropped into place. I then replaced the screws (in original locations) and everything was back to normal. My fear is removing it again. Is there a trick to replacing the platform on the 2002 model. The brackets kind of a wedge and pin hanging system.
That's it for now. Anyone's advice is apprecaited. Would especially like to hear from Andrew or Harvey.
Thanks.
Thanks.
