Problems turning left??
    I have recently purchased a 02' 22i. after putting several hours on it i have noticed that the boat does not turn left very well. When I make a right turn the boat cuts hard and turns sharp. But turning left is very wide and the front of the boat seems to rise up and prop cavitates. Even when I have more weight on the left side of the boat I still have this problem. I do have the front tracking fin broken but the other two seem to be straight. Rudder seems to be straight and turns the same distance left and right. Any help would be great.
    The rotation of the prop will effect the turning of the boat. The more weight you have in it the more you will notice it.
    also is it stiff? might need a new cable
    DW
    Tige, it's a way of life!
      No cable is not stiff and has been replaced recently. I noticed that the strut is off to the left of the rudder but after doin some research on here it seems they are all like that. Thought maybe I had a bent strut?
