I am looking for part # for impeller and helpful tips on when and how to change? thanks
2004 21i impeller
Looks like Part #: 47-862232A 2 to me?
http://www.perfprotech.com/mercruise...r/umodel/10718
http://www.perfprotech.com/mercruise...0?umodel=10718
http://www.perfprotech.com/mercruise...product/186958Mike Allen, Tigé owner since 1997
47-862232A 2 is the correct impeller for my boat THANK YOU, THANK YOU Mike Allen for saving me from the hassle of getting the wrong impeller. Mercurymarine.com is a little confusing using the serial # search. Once again this website has been very useful. I thought about not replacing the impeller this year, but good thing I did because one of the legs of the impeller was cracked. I am now going to replace the impeller every season. It only took about 1 hour and it was pretty easy.
FYI, the difference between the two is in the drive, the first part number is referred to as a "D" drive or single flat. The pump you have and the impeller that goes in it uses a double flat drive and neither will allow the installation of the incorrect impeller. All of the impeller length problems, and subsequent overheat issue upon initial start up, are on the crankshaft driven pumps. Be sure the o-ring in your raw water pump is either still re-usable or replaced correctly. Look for corrosion, seal expansion or bearing failure/water seepage while the pump is apart to avert more issues (for everyone else reading doing their own service).Fixing everyone elses boat just so I can use mine...
