I have an 03 21i.To get more hole shot I had the prop repitched to a 11 from a 12,now when I turn hard to right it cavitates.I also tried a 10.5 prop and had the same problem,any sugestions?The props are 3 blade Acme.Talked to Acme and they seam clueless.
prop blowout
You didn't like your hole shot? I have the same boat and think the hole shot is great. The only time mine cavitates is when I had a bent prop. If it's doing it all the time, your drive shaft could be out of sink.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Originally posted by tobo57
until I fill the ballast and load the kids on.I had my prop redone,I'm not shur if what I need may be a new one.I think a 3 blade acme 13/11 would be what I need.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
