I HAVE A 99 21i.WHAT IS THE BEST WAY TO WINTERIZE THIS YEAR AND MODEL BOAT?MUCH APPRECIATED!
WINTERIZING
I have the 6.0 Marine Power in mine. Its closed cooling system because of the heat exchanger it has. Mine is mounted on the top and starboard side of the motor. 3" tube with a bundle of coils in it. If you can be more specific, the guys can lead you to what you need to knowAin't no 1/2 steppin'
Originally posted by ST.TIGE View PostTHATS WHAT SUCKS.I DONT KNOW CRAP ABOUT MY OWN BOAT.IM AFRAID TO ASK QUESTIONS CAUSE I CANT ANSWER THE QUESTIONS YOU ASK ME TO BE ABLE TO ANSWER MY QUESTIONS.GOING OUTSIDE TO GET ANSWERS I HOPE.
It looks like yours is a standard open cooling system
What I've been doing is pump/run 5 gal marine antifreeze thru after it has warmed up on the fake a lake. It will all basically pour out of exhaust. Then pull all the blue plugs ensuring pink comes out of them, pull the hose of the sea pump pressure side, and the lower hose off the trans cooler. Your 3rd picture is a fuel cooler, it will have a blue plug as well. Should be about 4-8 plugs total. And as Bryce said Stabil in the tank and let the motor run for 5-10 min on fake a lake to ensure its thru the entire system. Its a little over the top on the antifreeze and pulling plugs but winters here can get pretty cold or they can be really mild.Last edited by Ruger761; 12-05-2012, 01:55 PM.
St. It looks as though you live in the gold coast area of california, I don't think it freezes there (I could be wrong) IMO all you really need to do is service the boat i.e. oil change, Fuel Stabilizer, may be a new water seperator if needed based on hours. I would suggest to drain the water as well. Just myGood luck man.
IT GETS TO ABOUT 28 TO 30 DEGREES AT MY STORAGE UNIT.I REALLY DONT WANT TO WINTERIZE IF POSSIBLE BECAUSE WE NEVER NOW HOW LONG WE CAN ACTUALLY KEEP BOARDING ON THE CENTRAL COAST HERE.I JUST KEEP WATCHING THE LOWS,MAYBE A QUICK WINTERIZING AND TUNE UP FROM THE LOCAL BOAT DOC WOULD BE THE BEST BET.MUCH APPRECIATED.Last edited by ST.TIGE; 12-05-2012, 08:25 PM.
All depends on your high/low temps. If lows are below freezing for a few hrs a day only and your still getting up into the high 40-50s probably be ok. But if your getting even one full day below freezing it can crack the block. All it takes is the water in the cooling jackets to freeze once. But its very easy to pull the blue plugs and let the water drain out. Might take you 10-15 min total. For quick cold snaps that dont last long a single 100 watt light bulb puts off enough heat to keep the engine above freezing.
