The high temperature alarm sounded on our 1999 21i. The alarm seemed to be intermittent and was going on/off for about 10 minutes before the engine was turned off.
The transmission fluid was subsequently replaced and the alarm is no longer sounding. I was wondering, however, if the high temperature is the result of just dirty/used fluid or if it is symptomatic of a more significant problem. Also, I'm concerned whether damage may have resulted from the high temperature condition.
Thank you.
Thank you.
