I have an '02 22iR with 350 mag 315 hp and stock 13 x 13 4 blade prop. With 800 lb.s of lead [60,40 towards the rear] and a few riders in the boat, I experience a lot prop slippage and cavitation.Any suggestions on a better prop size and or settup would be greatly appreciated.
prop
Try giving ACME propellers a call 1-888-661-ACME.
http://www.acmepropellers.com/.
They will probably set you up with a three blade. They will ask you all the questions to dial it in for your needs. You should know the RPM at wide open throttle (WOT).Mike Allen, Tigé owner since 1997
