Speedometer Calibration
    I have a 2001 20i and the stock speedometers are not as accurate as they could be. I recently ran through a slalom course and both speedos were off by at least 5 mph. These units are the stock Airguide speedometers with the wheel type pick up.
    My question is can the speedometers be manually calibrated and adjusted in the field or is this something that must be done by a tech at a shop.
    Any help is much appreciated!!
    David
    Yes, someone please shed some light on how to clean these lines, blowing air thru them?? How do?
      There was a previous thread on cleaning the airline by TigeMD. I'll see if I can find it.
      Does your speedo have the little turning knob to calibrate your speedo? Picture of yours?
        Found it. I hope it helps.
        http://www.tigeowners.com/forum/show...&highlight=psi
          Thanks for the link, I'll review the steps to clean the lines and hopefully re-callibrate.
          My airguides are sealed with no manual knob to calibrate at the speedo. I had a prior boat with this option and it was a nice feature.
          Thanks,
          David
            i have the same boat with the knobs I dont think they work ne better I've been dickin with mine all summer and still have no real idea how fast I'm goin
              You need to use a GPS to verify your actual speed then adjust the speedo with those knobs to match.
                This... Just get the GPS based perfect pass thats what I did
