I have read up on all the threads regarding replacing the strut bushing, but I can't seem to find any info on replacing the strut. My question: is there an alignment procedure when replacing the entire strut?
I bent the prop on a rock last weekend, and while pulling the prop, I figured I'd pull the shaft and check it out, upgrade to a new shaft seal, and replace the bushings if I could get them out without a fuss. That's when I noticed a crack in the strut, about a quarter of the way through. My guess is the vibrations while limping back to the dock was the cause.
Is alignment a big deal on direct drive inboards? I successfully removed the old strut and have another one on order, so what alignment do I need to check when installing the new strut to make sure everything is back to normal? I don't see any way you could twist the 6 bolts in the holes or tolerance difference in the strut to be a significant change to alignment. Is it as simple as bolting the strut to the hull and checking to see if the shaft rotates smoothly before replacing the prop?
Thanks,
Chris
Thanks,
Chris
