Hi Guys. I've been around for a little while but this is my first time posting. I bought a 1995 FSLM back in 2020. It's a decent old boat with lots of hours. I put on 60 hours last winter and about 30 so far this winter. We winter in Havasu from October to May and this is just a little boat we use to explore the beaches and coves and hang out in the channel.
So on to my question. I need to replace the steering cable and possibly the entire helm. From what I can tell my existing helm is a Morse D290 model with tilt. I can't really find any markings or numbers on the existing helm but from looking at pictures on like it appears to be a D290. The main reason it needs to be replaced is because the steering wheel has quite a bit of slop when turning left and right. Looking at the back of the helm I can't quite tell if that slop is in a worn out cable or worn out teeth on the rotary wheel. It seems like I can find a replacement cable for about $125 or I can replace the entire helm and cable for about $200. I know how to look at my existing cable to find the length.
How do I figure out exactly which helm I have?
Would just changing out the cable eliminate all the slop or will there still be some slop if the rotary wheel is worn?
If I decide to change the entire helm which model and brand would be the easiest to swap into my boat?
Do you have any other recommendations for reducing the slop in the wheel?
Thanks in advance for your responses.
Tom
Tom
