Spark Plugs
    Spark Plugs
    Hey,
    Sorry, not sure if this has been answered elsewhere, but I seem to be missing the search function on this page. I just bought an 04 tige 22i and am looking to replace the spark plus as well as the cap. I pulled a plug and it was the AC 41-932, which in researching has since been discontinued. Spark plug cross reference lists a lot of containers, but I am partial to NKG. Will any of these work...or has anyone had better luck with a specific plug?
    Also, I have had 0 luck in finding the cap that would need to go on this motor if anyone knows that.
    Thanks in advance,
    Brian
    What engine do you have?
      Sorry, its the MerCruiser MPI 315hp
        Also, it is stored in another state, so unfortunately I can't go pull the parts to get numbers. I am trying to get the info because I want to install new parts when I go back out next weekend.
        Thanks again!
          https://marineenginedepot.com/tune-up-kit-with-cap-2
            From what I could see. It looks like the plug was superseded by AC Delco 41-933
            I am a NGK fanboy myself. AC 41-932 crosses over to NGK PTR5D-13 (6644)
            AC 41-933 crosses over to PTR4B15 (5146). I would probably chose the 6644
              Great, thanks! Do you have any input on the ngk plugs to replace the 41-932's or would any work?
                We use AC plugs in a GM engine. I think the new ones are 41-993.
                  2004 might not have the flat cap what is the engine serial number?
                    Looking at an invoice looks like it might be 38193
                      And sorry, this is a 335 motor, not 315
                        Is it a Marine Power? What color is the engine, black or silver?
                          Don't recall color and its in storage. But its a marine power engine, model s5.7vsk i. Serial is as above.
