I got the amps mounted and powered just have to run the speaker wire, picture is wicked poor quality sisnt it was so dark, also got the dash remote installed, had to fabricate a plate to cover up the massive hole the other remote left, ill paint it black so its not an eyesore, also got the depth guage mounted and powered now i just have to install the sounder and run the wires.
I still have to run the wires in the tower, install the battery selector and the second battery.
OK this is what i did toight, got the batterys in, selector wired, cabin speakers wired to the amp, wire run for the sounder to the gauge.
Tomorrow i can hopefully get it all finished. Mount the sounder to the hull, run the wires from the tower to the amps, mount the rest of the neons, and make all the wireing look less ugly
Oh and also i happen to stumble across the taps pump while wireing, there is a pictures showing how low the oil is (even though it still works perfectly) and the pump without the top cover on. My question is, how do i refill it and what weight to i refill it with?
alrighty here we go, ive gotten everything in, and i love how loud this baby is, even with just two speakers on the tower. the subs bang so hard with the DD amp on them, depthfinder is mounted and wired.
Only thing i have to do now is carpet, and wrap, then she will be done.... untill i find something else to install on her
