Apparently, the manufacturer that Tige had making the glove box cover for this boat has gone out of business taking the secrets of producing the cover with them. Anybody have one to sell or know of a similiar replacement?
I would make a cardboard template and then take it to a someone that machines plastics, plexi, acrylic, UHMWP, etc and have them do a one-off fo ya. My guy here in town does the walk-thru windscreens for me for about $100. A small door can be too much.
you may try covering the lid with some color matching neuoprime or carpet like a dash pad. you can fix the cracks on the inside with JB weld and then then cover them up as well. you could make it look trick for a few $.
I got some epoxy and used a few bracing pieces fixed it right up, granted not the prettiest job Ive ever done but it holds very well and latches. Plus you cant tell from the outside. Also loosen adjustment screw on the hinge to make it move easier to prevent it from cracking again.
