Sitting at the dealer waiting for Spring.
cant wait R21
Originally posted by RICKTROTTIER61 View PostHow is your surf wave? Did you have to add more ballast?
This was my response someone asking the same thing.....
with our standard of 4-5 adults in the boat and running the factory subfloor ballast and surf XL bags, I've added a 350lb fatsac on each rear side seat--so running front to back and run them full. Then I have an 800lb fatsac for the floor and vary the amount depending on people and wave desired. I've rarely even come close to filling the center bag more than about 3/4 full
I'm actually working on a video right now showing all my setups as well as results, it should be done here in the next week or 2
Originally posted by MtnMan210 View Postsurf wave is pretty good out of the box, but yes we added a good amount more ballast to get it where we want. I've got the boat pretty dialed in as far as surfing goes. The next thing that needs attention is the prop. It seems a little slow on the pull up and then when the boat has 5-7 adults plus FULL(everything we have) ballast it wouldn't get on plane.
