Just finished re-framing the garage for an 8' door. My Z1 is ready to come out of the rain.
New Garage Door for my Z1
Does the water pool up on your cover using the tower strap? I find mine is terrible. I have to use the pole on the inside.
I actually think my 2013 cover has the hook attachment installed in the wrong place. It is way back along the back seat. I can't tell from this image where yours is. When I install the pole, it is on the floor up against the rear step seat.
I don't use the pole and the only place I get water pooling up is around the tower pockets. The pole would not fix that problem if I installed it. The loop is about 1 foot behind the tower tow point. If I did install the pole it would be in the middle of the floor. My wife was upset, but I convinced her to put the new door in so we could store the boat inside.
probably one of the best and most overlooked items for covers if you ask me. we make it a standard install item for all the covers we make.
love the color combo on your boat too!
http://www.vicomarine.com/2011 Tigé RZ4
www.re-viveupholstery.com
Here is what mine does in the rain. Sorry for the blurry pic.
The pole solves all the issues. It needs to be quite high though... probably 4 feet.
Mine with the tower down (and Boatmate trailer) is 75" as measured at the highest point (the windshield) However that is a bit of a misdirection depending on the driveway. Mine is quite steep, so the tower actually gets closer to the door since it is right above the wheels. The front end dips down and the tower tips up as the truck pulls it lower down the driveway. (if that makes sense). My garage door opening is 82" and it takes all of that. So go with 82".Last edited by JohnnieMo; 07-08-2015, 04:43 PM.
Originally posted by Clug Z1 View PostMine is 7' 4" with tower down.
ps - your boat looks great. I like the accent green.
Originally posted by Z1owner View PostWe did the same garage door modification. The things we do for our boats! BTW our 2015 Z1 is 7 ft 4 in. The high spot is the folded tower. It's slightly higher than the windshield.
Originally posted by JohnnieMo View PostJust for comparison's sake, how far is the bottom of your prop off the ground? How far from the prop guard? It looks like your trailer is quite a bit different than mine.
looks right to me, for a trailer with larger diameter wheels. The bunk supports are longer because the hull won't fit between the fenders due to the upgraded wheels. I had to fit mine in a 84" door, so that was the primary reason for not blinging out our trailer.2013 Z3 - Electric blue and black
