Here are some pictures of before and after I changed color/graphics/interior of my boat. I think it turned out pretty good. Let me know what you guys think
2008 Tige 20 V completely redone.
Looks pretty good. Why did you swap out everything? I would be hard pressed to change out 4 year old vinyl unless it was really trashed or something. The reason I ask it that I have never seen a re-upholstery job that is on the same level as the original in both fit and durability. Those rear corner seatback cushions look a little loose and will likely tear/wear much faster than you would like. I would see if the guy can make them a little tighter.
Anyways, looks great.
When I bought the boat I was really set on getting a Black one, but they couldnt customize it they way i wanted it in time for when i needed the new one. My old 21I was red also. So I took matters into my own hands this spring and redid it. The boat also has almost 750 hours on it so the vinyl was definitely starting to show some signs of wear.I'm not the kinda guy that lets his boat sit in the driveway and look pretty. Probably some kinda record getting from 0 to 750.I decided to change it to the original color i wanted while i was at it. But i agree with you about the back needing stretched a little tighter. Other than that it turned out great.
