Clean Up Supplies
    Clean Up Supplies
    OK -- so in my excitement of my perceived value and boat purchase, (http://tigeowners.com/forum/showthread.php?t=9729) I forgot to mention one thing.
    Previous onwer had it on shore station and it sat a tad in the water -- so it has that nice, light green algae coating that has some minor spidering (my term) of the algae -- I've seen worse, and cleaned up worse on my previoius boat.
    So -- what would you recommend that I add to my elbow grease to clean up the hull? And, what would you recommend I use to bring the shine back out of the fiberglass and graphics?
    I have used a very mild super low grit rubbing compuound on previous boats with good results.
    Recommendations appreciated.
    Thanks!
    Go to Westmarine and get some hull cleaner. Apply liberally (you can just spray it on). Let is soak for up to 24 hours and rinse.
      Then follow with a good polish like Flitz or somthing.
        x2
          Have it acid washed. Just drop it off dirty and pick it up clean. No hassle or manual labor.
