I was dewinterizing everything and snapped the wire off on my knock sensor. I had way to much other crap going on to mess w/ fixing it at the time. Does the knock sensor unplug anywhere or does the wire go straight back to the ECM. Can it be soldered back, or like I said... is there a plug that I can unplug it from and just replace it quickly enough?
Better question is, will the MP 340 still run w/o it like some ECM's will allow, or is it programmed to go into limp w/o it?
Yes I stole the pic from CHP
