TAPS WONT MOVE PLEASE HELP
    CUT THE WIRE TO THE DC OUTLET ID THE GLOVEBOX WHERE RAIDO IS NOW MY TAPS WONT WORK ANY SUGESTIONS. it apears that my gage is working because when you turn on the ignation on it gose to 1 which is normal.The boat is a 2003 21i i have checked everything ready to BLOW IT UP.
    Splice it back together?
    IDK why that wire would have anything to do w/ the taps though. The taps wire is a green wire that runs from the guage to the throttle lever, back to the transom of the boat, all along the starboard side.
    Have you checked to see if any of your breakers are popped?
    Are you absolutely sure your taps was working before you cut it?
    Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
      Mine is on a breaker on the left side of the panel there are two of them that are normal opened so so that battery drain is minimal
        YES IT WAS WORKING FINE PLUGED THE WIRES BACK INTO THE DC OUTLET TAPS IS STILL DEAD NO POPED BREAKERS. ????????????
          Check your fluid level, make sure it's full.
            '03's were electric.
            Check the wiring under the dash. I know there is some ground wire there. Also check your fuses at the battery.
            Common Sense is not so Common
              turns out it was the reset breaker it was bad . thanks all
