I dinged up my prop last night, went to my local prop shop to get a replacement and he gave me the completely wrong size. He gave me an acme 13.5 x 17.5. No power, with a top end of about 35mph @ 2400rpms. Plus there is a weird whistling noise when I put it in gear forward, and stays there until I give it gas.
I checked the shaft alignment and struts everything seems good. The dinged up prop wasn't that bad.
Suggestions for new prop? And the whistling noise?
Specs-
2002 23v
I just want to get a little better hole shot when I'm loaded down, the 13x13 seemed to be fine, even when we had over 2800lbs of weight, just a little sluggish.
Specs-
2002 23v
- 1.1 gear ratio
- 13x13 oj 4 blade prop was on there (don't know if it was stock
- around 2000lbs of ballast and people, sometimes more
- 2000ft elevation
