At the end of the last season I noticed that when I punched the throttle to tow someone there was a slight vibration for the first 2 seconds and then it went away. I took it out today and the vibration is longer and has trouble planing out quickly. I took it to the dealer a few weeks ago and they could find nothing wrong with the prop. When I look it seems that the shaft is off the the side of the entry into the hull. Any thoughts? Going to take it back in Tuesday.
help! vibration at takeoff
Originally posted by dogbert View PostIt doesn't sound like the prop. I have the same issue. I need a new shaft. It's slightly bent. If your strut has the shaft off to one side, then you may need a new shaft too.
Did you hit anything?Common Sense is not so Common
Originally posted by Waterski-Rebel View PostTake the prop to Jim's prop shop, and have him test it out. He's got better equipment then WWS when it comes to props. Also, WWS subs their prop work out to a traveling prop guy.
This is nothing negative against WWS, I think they are great. I just think Jim's is better for props.
Originally posted by DieselPWR View PostNo I didn't hit anything, but I may have moored it too close to shore last labor day. Had some kids jumping on the swim platform.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Check your shaft/coupler alignment. It's easy to do with a set of feeler gauges. I don't remember the exact spec, but I think that it's a difference of .008. I'm sure that someone on this site can tell you the exact procedure if I've missed something. It's been a while. All you need to do is loosen the bolts holding the coupler to the prop shaft. rotate the shaft and use the feeler guage to check the alignment. If it's out of whack it would cause your vibration.Indecision may or may not be my problem
Originally posted by DieselPWR View PostTurns out it was the prop, one fin was slightly out of cup. Was told it can't be recupped so had to get new prop.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Call Acme before buying a newMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
If the cup is damaged or bent around the hub or anywhere near the hub the prop is trashed. I have spent a lot of time with one of best in the nation when it comes to repairing ACME props and learned a lot from him. He has a laser system to check and repair the props.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
