Wind blocking
    Wind blocking
    Do they make a wind blocking accessory for the walk-through bow that fits below the winshield? I have a 2003 20i
    we install a plexi glass shield thal slides down the walk thru. it will cost about $150 installed. it could be a little more if i don't have one in stock for your boat. when buying a single i don't gat the price break.
    Greg Denton
      Our Dealer had one made for us from canvas. The only way to go on a cold morning! SkiDogs in Seattle was the dealer
        windblocker
        we have the folding door that fits under the mid window when open. a Tige option until 2005. its nicer than the cover on the bow to block wind. also keeps little kids in the back area. when closed it is flat against the side. there may be some still around . check Staton Motor Sports. i think joel ordered the lasst of them. 503-769-6666.
          yes Tige make a Lexan ( I think thats how to spell it) cover. It basically slides into 2No. guide rails that screw into the fibreglass. Works great.
            twenty bucks
            if your strapped for cash and wanna save some money i got cheap way to do it.
            take the measurments in the bow from the window to the floor
            width and height
            go the hardware store
            get a piece of plexi glass cut to those specs
            get another piece about 4-6 inches by the width of the space you measured
            attach the two with hinges
            two will suffice
            drill the holes other wise the plexi will crack
            then use little bolts not screws
            slide into place and you are done
