I have seen many of post about the above but have two quick questions.
Impeller- My boat has only 37 hours on it, 2008 22ve, having it dewinterized by a reputable Tige dealership and I asked to have the impeller changed, he said it was not necessary, I have read that most have it changed every spring, seems like a very important and relatively cheap preventative care issue. I did not argue with him since his knowledge is exponentially better than mine. What are yalls thoughts. Should I push the issue.
Bought and having a 3 vent (two hot tube) heater install, do yall any picture of where the Tige "factory" installed heaters look like and are placed.
Hope to be on the water by first week of April, I am going to use the personally modified "Old age 100 degree rule". Water temp plus air temp plus the age of the person getting in. I figure that is more accurate than the original. I will see how it works.
Thanks.
Thanks.
