Can someone tell me how often to replace a impellar.
impellar
Some do it at the start or end of each season buts its not necessary. This just reduces the chance of having a blowout over the summer.
It is mandatory to have a back up though! It will ruin your day! I know because it happened to us.Common Sense is not so Common
Every other season (in the Spring) at the least, but a lot change it yearly. When you do, take a real close look at the housing, most repeat impeller failures are a result of a bad housing.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostEvery other season (in the Spring) at the least, but a lot change it yearly. When you do, take a real close look at the housing, most repeat impeller failures are a result of a bad housing.
It can last two seasons but for $40 an impeller, it's definitely cheaper than purchasing a new engine.
Originally posted by brody66 View PostI know it has been covered in many threads but how long does it take to replace one on a mercury 350 mag?
and if you have the right replacement part (dbl or single)
I think it depends on silt in water and if you let it dry out over the winter
Originally posted by brody66 View PostI know it has been covered in many threads but how long does it take to replace one on a mercury 350 mag?Common Sense is not so Common
Originally posted by da.bell View PostBrody's probably has the Marine Power engine in his boat. That is four screws and a PITA to get into that area.Common Sense is not so Common
Originally posted by da.bell View PostBrody's probably has the Marine Power engine in his boat. That is four screws and a PITA to get into that area.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
