Where do you drain the oil on this model cant find the remote drain line. Also dose the merc 350 mpi hold 25w40 4 cycle at 4 quartes.
2003 21 i oil change
Punching a hole in the filter will dribble oil all over ... wait, damn, that filter's mounted upside down. Guess I'd do the same.
Get a drill driven pump and hook it to the drain line. It takes about 15 minutes. Otherwise, you're looking at days for it to drain with a cold engine. You'll need five quarts with the filter. I use 20-50 Castrol.
I did not do the 20 hour check the dealer did so I am wondering does the 20V with 340HP Marine Power have an oil drain line or is it the old fashioned pump out way. I have a good pump, the Tempo Oil Boy Extractor that I used on my previous I/O. You can get all the oild out in about 10 minutes once you get a godd vacumn pull going.
Originally posted by MoneyPity View PostI did not do the 20 hour check the dealer did so I am wondering does the 20V with 340HP Marine Power have an oil drain line or is it the old fashioned pump out way. I have a good pump, the Tempo Oil Boy Extractor that I used on my previous I/O. You can get all the oild out in about 10 minutes once you get a godd vacumn pull going.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
MP, it does have a oil drain line and you will NOT punchure a hole in your oil filter. The filter is located on the starboard side on the lower part of the engine. The oil drain line is located towards the port side towards to the bow on the engine.
Will take pictures if you need me to to explain.
Originally posted by da.bell View PostMP, it does have a oil drain line and you will NOT punchure a hole in your oil filter. The filter is located on the starboard side on the lower part of the engine. The oil drain line is located towards the port side towards to the bow on the engine.
If it is as slow as chp says then I will use my extractor.
Now if I can only figure out where this silver box MP sent back to me after the flashing for the speedset surging issue. I think it bolts on just in front of Air cleaner.j/k
Happy Sunday all.
Originally posted by MoneyPity View PostNo I think I got it. I can recognize an oil filter and now that you have described location of drain hose I am set. I would never puncture the oil filter
Happy Sunday all.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
