Yes, but only for a specific set up i.e engine, trans, altitude, etc. Call ACME and tell them what you got and what you want to accomplish, they will set you up with the correct prop for your application.
Correct but based on Jake's eventual RZ4 purchase, this is the prop that needs to be purchased to allow what he wants to happen
For Jake, yes, but not Carter's.
Correct but again, I don't know about Carter's new boat either I'm a tige dude!!!!
Yep, I just didnt want carter, or anyone else, the think that the 1235 was the fix-all for their boat to, that's why I suggested to just call Acme direct for prop rec.
Even with some ballast and peeps, the 537 will push strong in these boats, especially with the 340.
Well I have the HP and normally only have 5 peeps on my boat when it is my turn to burn fuel so staying same as stock prop should work out for me.
I pull mainly slalom skiers and sky-ski fanatics. My daughter can board as well as brother in law.
We also have about 230lbs in Labs and 20 for our hot dogs. I also keep a full array of tools in boat and on weekend trips my hydraulic jack so I guess with that weight we may be just at the 6 adult a kid equivalent load. With stock prop it had plenty of out of the hole and if the driver was not nuts we still had attached arms when slaloming. That little boat sure has some pull.
One thing I noticed is that the weight of the boat has varied by hundreds of pounds. At one point it showed on the Tige site and reviews that the 07 is 3700+ lbs. Anyone have an idea as to real weight.
"EVENTUALLY" we'll be going down to the keys as well. Eventually we're planning 2 trips a year. The Garmin 535 is perfect in the sense of screen size (to mount and fit on the RZ4 dash). Added with Vision G2 map option, you get cool stuff like the pictures below.
If I can just talk da.bell into coming down to the keys with us???
The lower keys are tuff to navigate by day and impossible by night. We want to max our wakeboard / fishing / cruising experience.
Here's a pict of the 535S and some pictures of the optional G2 vision card.
Forgot to add....Our "eventual" boat weights in at 4400lbs stock, but with all the add-ons from Wetsounds, I'll bet you it comes in close to 5000, then "eventaully" add ballast, kids, Dad, food, beverages, two water rafts, 3 boards, 3 wake skates, custom bimini, garmin, ice, towels, umbrella, eventually maybe da.bell will join us, so on and so on.....the damn thing will be well over 6500 lbs.
I'm wondering what 2500 watts of bass will do to the fish down in the keys? Do you think it will attract sharks or repel them?
You'll have Greenpeace wondering what the Navy's up to now as whales go deaf, and the Navy wondering who's jamming their long range sonar/listening devices with Ted Nugent, P-Diddy, Aretha Franklin, Boy George, or whomever you're into. With an eventual boat you can do anything.
