I missed this one, what happened with tige'GM/MerCruiser. 09 boats are PCM only? Charley used MerCruiser since 92' . jeff
PCM only?
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by dozzerdude View PostI missed this one, what happened with tige'GM/MerCruiser. 09 boats are PCM only? Charley used MerCruiser since 92' . jeffPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
The engines are still GM as they are the only ones building marinized blocks, but Merc went away in like 04-05 I think, and PCM for 09. (with some early 09's having MP's available as they still had some in inventory)Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by formandfunction View PostThere all the same thing.What make one louder than another?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
As far as "way more powerful" as posted earlier, HP is HP and I'll bet the MP has a better torque curve then PCM. I'd love to see both, but no one publishes them. Ive driven a CC 236 (heavier then my 22Ve) with the pcm 390 (more hp and more cubes) and I'll put my MP up against a PCM any day. better hole shot, quicker acceleration, better MPG's. Not knocking the PCM's so no one needs to get their panties in a wadebut the PCM 343 just doesn't hold a candle to a MP IMPO.
Originally posted by chpthril View PostThe PCM uses a single exhaust and a different baffle setup then MP.
Originally posted by chpthril View PostOk, just double checked the PCM website, and they list the TQ for the 343 as 430, but do not give an RMP for that spec, so it's not really worth a darn. Need to what the specs are at the normal RPM range that we run at.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by formandfunction View PostThere all the same thing. What makes one louder than another?
My friend's 2004 Malibu 350 GM Vortec motor was a lot quieter than our 2000 MAG MPI Mercruiser. The Malibu has 2 large mufflers packed in there to cut the noise. Ours is a little quieter than the Malibu after installing an FAE.
The guys at OBD Diagnostics say the engine control data for the Mercruisers is very conservative and tend to run rich to keep the valves cool. I have a spare MEFI programmed with the Ramjet data they say will probably make a noticeable difference. I haven't plugged it in, yet, because our boat has plenty of power. Especially, after gearing down a ratio with an Acme #537. There are so many variables - prop, cam, valve size, port size, computer data tables, weight, altitude, air mass, hull design - it is really difficult to make comparisons. I just wish they would quit changing stuff all the time so finding parts would be easier.
Keep in mind the initial reason for the switch to PCM engines. Catalytic Converters. California is a large part of Tigé's distribution and PCM offers not only catalytic converters, but they are also the best and longest tested design.
Add to the fact that PCM's renowned quality, customer service, dealer support, and marketing support....the switch was a natural progression in our efforts to make the best/highest quality boat on the market!
Originally posted by gman View PostSure wish they would have kept the dual exhaust. It looks funny at least to me with a single exhaust.
