Annual 'Let's look at the Lake Powell Snowpack' thread
    Of course I live in CA and I don't know much about the subject. I'm in Southern CA and I can't imagine anywhere else having more water conservation methods than here. My understanding is the bulk of it goes to Agriculture. I'm not sure how CA agriculture/farms compare to the surrounding states?
      Im also no expert on the subject but theres a few thing that strike me.
      1)Mead will always keep getting water because they are always going to keep the Colorado flowing. So in winter months with little melt or drought periods Mead is always getting inflow and Powell has to keep discharging. They cant just hold it when times are lean. Id be curious to find out the minimum CFS that is discharged?? Also curious minimum CFS Mead has to send down to Havasu??
      2)I occasionally peek in at the site Talltige linked. Even if the lake went up 50 ft its still 80ft from full pool. Thats a ton of water to recoup with everyone trying to get a piece of it. Seems crazy. Other piece of data that blows my mind on that site is that theyve already discharged 60% of their requirement and its only April??
      Going to get down there one of these days. Flaming George is on my list too.
        mike, no expert either but have read up a little and know that cali gets the bulk of the water to the point that if mead ever hits the level that the feds step in to start managing(which is expected by 2026), nevada and arizona lose first.
        we have a watersmart program here where they pay you $3/sqft to remove real grass from your property and replace with desert landscaping. lots of requirements/inspections to it and once converted the property is forever marked that it cannot have real grass again(when buying a house it's part of the disclosure process now). tons of people taking the offer from businesses to homeowners and it'll pretty much pay for rocks/shrubs and depending on your landscaper you can get a chunk of frass installed. wonder if other states are as well.
        2012 22ve.. RIP 4/17
        2014 Z3.. Surf away
          I have a friend that is totally into this and is always talking to me about it. That's about the limit of my knowledge.
          Here is an example of the water use restrictions in the construction side of things.
          https://www.sandiegouniontribune.com...n26-story.html
          Here is an article about the CA agriculture/farming side of things. It sounds like they take 80%.
          https://www.washingtonpost.com/blogs...=.838d76dbc447
            interesting on the wash post article. farmers using the same amount of water since the 1960's and looking at the chart of where water comes from 2001-2010 the colorado river is pretty constant minus a slight drop in 2005.
            but yet I remember reading somewhere that mead water flows were set up on some "record" water years and have not had since. water users as a whole continue to take from colorado and water supplies are not able to keep up with demand set up on long ago record storage amounts.
            that all certainly contributes to the current state.
            reading that and others if the gov't steps in, nevada/arizona and based on that article cali residential users are going to suffer long before the farmers ever do. water will still be available but at what cost. farmers will turn to selling water shares yearly to cities vs growing crops. we all now pay more for water and crops while farmers continue to flourish. looks like I need to switch occupations
            now reality is mead/powell/havasu are not going to go dry in my lifetime but selfishly don't want them to go low enough to kill boating until I retire from it.
            2014 Z3.. Surf away
              Remember that water years are kind of like school years. The water year 2019 ends at the end of September (I think), not Dec 31.
              Be excellent to one another.
                Larry, estimates on lake Powell peak elevation this year?
                  2 years ago when there was similar snowpack, the lake went up 40 feet. The lake is currently about 40 feet down from where it was last year at this time. So I am expecting it to go back to where it was last year. About 3610 feet. But it depends on if they decide to let more through to Lake Mead and I do not know where they hide that information.
                    https://news3lv.com/news/local/winte...d-water-levels
                      Two weeks to go until Memorial Day with 6 feet to go for Castle Rock cut-off minimum safe elevation.
                      11 feet to go until Antelope Point launch ramp reaches minimum safe elevation. Crazy.
                        Current rise rate is just over a 1/3 of a foot a day... Unless rise rate increases dramatically, I don’t think the cut-off will make Memorial weekend, but should make it by the end of the month. Antelope will be in June... Crazy how low it is...
                          interesting read from the media.
                          Bunk says, while we may not really see the water level rise in Lake Mead anytime soon, we also aren’t likely to see those dreaded water restrictions either.
                          interesting that since it's still below full why they don't enact some restrictions until it's full again?
                          I know lots of politics and water rights issues at play but take advantage of a good year and suck up the water usage until they are both pushing full capacity again.
                          2014 Z3.. Surf away
                            I suspect that it will be increasing by a foot a day pretty soon. It will be a race to see if the cut makes it open by the holiday. I would not lose hope yet!
                              Current snowpack. Still a lot of runoff to come.
                                [ATTACH]50974[/ATTACH]
                                The other site quotes the snowpack as 544% of normal snowpack for this time of year. Most of that snow is supposed to have melted by now. I suspect we are going to have some huge runoff now that it is heating up. This is a good setup for flooding.
