I was thinking of putting a fresh air exhaust on my 20v this winter and was wondering about the installation. If i read the instructions on the website right you have to drill some holes in the hull. Does anyone know if modifying the hull of the tige nullifies the lifetime warranty?
fresh air exhaust
Butch;
Do yourself a favor. Before you accually install the Fresh Air system, lay out all the parts, and pre read the dorections. Surfdad suggested this to me, and I foud it saved me a lot of time. This way, you can have everything allready figured out in your head, and all you have to do is install. The toughest part for me was the installation of the support bars / tube that attach to the swim deck. Make sure you pre fit these before you cut them to size.
Please don't be offended by my recomendations. You may be an ace mechanic for all I know. Just wanted to share my expierience when I installed mine.
P.S. You will LOVE it!!"Just Surf Damn it"
P.S. You will LOVE it!!Let it be!!!
Thanks in advance for the great advice .
I am installing after I get order using the January $100.00 off special.
Order by 03-Jan and get delivery by mid March 09 and get $100 off.
Is it worth getting it plated or is black OK? It is either under water under the platform or removed when put in garage so I am thinking save those $$$ for the WS-420 later!
Is it worth getting it plated or is black OK? It is either under water under the platform or removed when put in garage so I am thinking save those $$$ for the WS-420 later!It wasn't bad to install, I am just very picky about doing thing right and so they look good.
Dale
2000 21i Tige
Is it worth getting it plated or is black OK? !Other then than, you never see it
I'm happy with Black.
Originally posted by chpthril View PostPlated looks great every time you remove or install the plugOther then than, you never see it
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by TRD View PostI just put the black on mine and it looks fine. Remeber to follow the instruction. I had to take mine on and off 3 times because I missed 1 step. Just happen to one of the important one. The all thread rods need to be inseted in the holes before you bolt to the platform. You can't get them in afterwards.It wasn't bad to install, I am just very picky about doing thing right and so they look good.
Be excellent to one another.
We probably will use the platform quick release kit because I will have to disconnect when I put in garage. At least from what I have been told I expect that to be the case. The FAE tube extends past taps plate and even though I have some spare room I am pessimistic and am thinking the FAE will extend too far past the taps plate.
I figure between the tower, the platform and the FAE I will spend about 15 minutes taking things off /down or putting things back up/together every time I take the boat in and out of garage. Since the FAE tube is bound to get dinged why spend the extra money to look at chipped plating.
Originally posted by talltigeguy View PostSo I then put the threaded rod in upside down so that you do NOT have to remove the swimstep to take them off. The bolt you turn is between the mounting rod and the swimstep. There is about 1/2 inch in there for the bolt and rod.
ThanksDale
2000 21i Tige
Tigé Jedi
- Feb 2006
- 4601
- The Peoples Republic of Oregon
- 2007 24Ve (sold, but I do have a Waverunner….lol)
Originally posted by dogbert View PostMine's black and it's still in great shape...matches my TAPS plate.Originally posted by xpjim1 View Postmines black. The powder coating is peeling from the inside. Not worth the effort to take off and send back. No one sees it in the water.
As everyone has stated, lay everything out first, I had an issue with the bolts Dr. Mann sent and needed a different set......measure twice and cut once.
Originally posted by sparky216 View PostMines shiney and plated.......*bling bling* Actually when I ordered mine I didn't have a choice, just got what they sent.
Hey, maybe I should get a chain link steering wheel!Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
