poles for cover
    poles for cover
    How do the support poles for the stock cover on the RZ2 work?
    Where does the webbing hook up to?
    I think to the pop up cleats... I have not used mine but that is where I thought I would hook in.
    If its not fun, Why do it?
      not sure abuot the support poles
        White webbing with buckles and short pole go up front in bow, black straps with loops and tall pole in main cabin, single strap connecting the plastic pole caps goes over windshield. Front straps will loop through the front cleats (I believe) and the rear loops through the rear cleats. Tighten the Fast-Tec buckles so everything is taut.
          This is what I thought also.
          If i was using the right pole, which I think I was, they do not reach to the aft cleats.
            The tall pole goes to the floor right?
              Both poles should rest on floor. If the rear loops will not reach and the buckles are loosened up, move the white straps to the front half of the hand rails.
                chpthril--Man you just have all kinds of answers today
                I think I will have to play with it somemore
                  Probably the #1 reason why I just store my RZ2 in the carport. Those poles are confusing.
                    I need to put the poles in. The last rain put about a 50 gallons of water on my cover.
                      right or wrong, I got'em
                        I connect the white straps to the bow handrail. Black straps to the rear cleats.
                        "the plural of boo is booze."
                          Play with your pole (s)
                            connect the rear black ones first, then adjust the front white ones so that they will be tight. The cover for the Z tower always seemed to allow some water to gather on top of it in the back right behind the windshield also.
                            WAKE ZONE
                              I played with my pole(s) yesterday and got it all figured out. I was mistaken, the webbing coming off the aft pole is long enough to go to the aft cleats.
                              Thanks everyone.
