I have a 07 24Ve I bought it in December last year, We first put it on the water in April by June we had our 30 hr service. Now we have 90 hr's on it. I just took it in for some service work and one of the thing was the error buzzer. When the buzzer went off I checked all gauges and everything was great. The buzzer lasted for about 5 seconds. Well the dealer just called and said my boat was 2 quarts low on oil. There is no signs of leaks anywhere the dealer said it is burning it. I have never had a new motor burn two quarts of oil. I was told a marine motor burnes oil more than a car motor. I have been around motors for my whole life and have never heard of this.
Marine Power concerns
There is a dipstick recall that your dealer should have known about. I'll bet they under filled it at the last serviceMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
1st at 20hrs and then every 50 or at winterization.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by dogrocco View PostI asked them that and they said that was checked and mine did not need to be repaired.So what is the averge hrs' for a oil change this year we did 90 hrs.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
^^^ hate to say it, but that's my gut feeling.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I just spoke direct to Marine Power on Monday about some other issues and the oil consumption on my 2008 340 hp. They very emphatically told me that they WANT to see oil consumption at the rate of approximately 1 qt. every 20-30 hrs. For what it's worth they said that their motors have much softer rings than a "normal" automotive engine because they want a little blow by for more top end lubrication. Don't know if this helps or not but that's the story I got.Work because I have to eat, ski because I have to live!
Send a PM to MP's rep, tlbarrett, he will get back to you I'm sure.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by onevalkyrie View PostI just spoke direct to Marine Power on Monday about some other issues and the oil consumption on my 2008 340 hp. They very emphatically told me that they WANT to see oil consumption at the rate of approximately 1 qt. every 20-30 hrs. For what it's worth they said that their motors have much softer rings than a "normal" automotive engine because they want a little blow by for more top end lubrication. Don't know if this helps or not but that's the story I got.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I have about 800 hard hrs on my SBC and it uses no oil between changes and I typically change it about every 30 hrs. I sent an oil sample off once couple months ago when it had about 25hrs on that oil change and the oil I removed had some life left in it but not 75 hrs more for sure. I would feel better changing the oil early rather then later and 100 hrs seems like a long time for a marine engine, at least IMHO. I typically change oil more often the average bear because it makes me feel better and oil is cheap...well sorta. I would be curious what an oil analysis report would be for a 100 hr change, I bet it is used up.
I am very skeptical of the MP having"softer rings". As far as I know every marine engine rolls off the same GM power plant line before going to Mercruiser, Volvo, MP or whomever for marinerazion. A quart of oil every 20 hrs is nutz. I would do leakdown test and go from there.
I have the same boat that you do, an 07 24ve with an mp engine, and my boat was using a lot of oil just like yours, we had the issue with the dipstick at first. After we got the right dipstick in it it still kept using oil. My dealer did a compression check and two of the cylinders were running at about 20%, So they ended up sending a new long block and putting it in the boat. I was without my boat for a month.
