What kind of issues are you having? What motor do you have?
If MP you might want to email tbarrett at tbarrett_marinepower@cox.net and see if there is a Certified MP shop in havasu. If mercruiser Shimmer Marine has helped me in the past on my old tige
was under the London Bridge running no wake and the motor started running rough then died. about 10 min later started right up ran for about 10 or 15 min then did the same thing so I got a tow back to the docks. I talked to my dealership mechanic and he thinks it may be the low pressure fuel pump but wasn't sure and said I should take it to get the fuel pressure tested.
Thanks for the help xpjim1, I should have looked at the forum before I posed, I guess I am just in a rush and want to get back out on the water, I am going to take it to Absolute Speed & Marine
