shaft seal leaking
    shaft seal leaking
    I have a 94 SLM Comp 2000, and over the past couple years it has started to leak, getting worse each year. I thunk it is leaking around the drive shaft, two years ago a friend tighened a nut on the shaft which helped the problem for a while but the leaking is getting worse. I did not what exactly he did at the time and am not sure what to do. I tried to tighten a nut with the boat out of the water and it seemed really tight, and I did not want to over tighten. Should this be done in the water? Also a friend said I might need to repack the seal with some teflon rope packing. Is this an easy procedure? Any help in this problem would be greatly appreciated.
    Try these threads. Lots of info and even some pics.
    http://www.tigeowners.com/forum/show...hlight=packing
      Thanks RZMike for the links, it should be a big help.
        No problem. If you still have questions after looking through those threads, post again and we'll get you fixed up
