I went out today to the ramp, to check it before towing all my crap to it tomorrow. Finally remembered to take pictures. Due to many people getting stuck, they now are requiring 4wd, it was just recommended before. Here is why people are staying away.
Close up you can see the small steel grate they put down.
Here is a look back up the ramp.
You can see the secondary ramp, and then higher, the primary, we are way below both.
And from the top down.
Even though the lake is lower than last week, the ramp actually looks better. Since labor day, less people are using it, and now they are not allowing 2wd, so the spot just above the steel grate is no longer a muddy hole. It was very hard before, just higher than the great was a big mud hole from all the 2wd trucks spinning there tires.
You can't tell, but it is VERY steep.
