Originally posted by lincdarrow
View Post
stainless rub rail '08RZ2
Originally posted by lincdarrow View Post1. the cruise control does not seem to work. It might be user error.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I turned the swith on. Yhe Set Speed is in the upper right and the actual speed is centered large on the bottom of the screen (great display). I pushed the "up button" and nothing happens to the 'Set Speed' screen, it justs stays at 0.0. I also tried the other recommended way to get to speed and hit the "set" button and nothing happens. I wonder if there is a fuse for the speed set? Of course if there was a fuse then when I swiched the master rocker switch on then nothing would happen. The set speed never left 0.0 all weekend after numerous attemps.
I figure there will be a few bugs in any new boat with electronics.
Also at full throttle the depth finder goes to 997.0' when I back off a bit it comes back to reading depth, so I figure vibration os causing the depthfinder to lose itself.Fat, Drunk, and Stupid is no way to go thru life.
Dean Warmer '68
Originally posted by lincdarrow View PostI turned the swith on. Yhe Set Speed is in the upper right and the actual speed is centered large on the bottom of the screen (great display). I pushed the "up button" and nothing happens to the 'Set Speed' screen, it justs stays at 0.0. I also tried the other recommended way to get to speed and hit the "set" button and nothing happens. I wonder if there is a fuse for the speed set? Of course if there was a fuse then when I swiched the master rocker switch on then nothing would happen. The set speed never left 0.0 all weekend after numerous attemps.
Depth Finder = Air bubbles going across the pick-up. At WOT, the boats is barely in the waterMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
NO GOOD.
The light on the toggle switch does not come on. I started to pull the switch panel out and all of the wires appear to be connected well to the toggle switch.
All of the other toggle switches light up when switched.
Where do I go from here??Fat, Drunk, and Stupid is no way to go thru life.
Dean Warmer '68
You will find that most of the non-essential components are protected with an in-line fuse V's a manual-reset breaker. If you lay on the floor and look up behind the dash, you will see numerous black plastic in-line fuse holders. You may be able to trace from the switch to the SpeedSet's fuse holder, but it may be easier to just check them all.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I like it. The folding option is really nice. It fits in my garage.
It moved some when the racks were loaded and we were in 1'-2' chop, but nothing like my frineds Mastercraft x-30.
I am happy with it, and I like the looks a bit more that Tige's factory tower.
The Samson Speaker system / connection is awesome.Fat, Drunk, and Stupid is no way to go thru life.
Dean Warmer '68
