Have a 2008 RZ 4 and it seems it doesn't matter what we do the wake on the right side just does not shape up like the left. It seems like it is always washed out and not as crisp as the other side, regardless of speed 18-23 it is still the same. Any input appreciated.
Wake problems
You need to balance your boat side-to-side. This may mean moving people around to make that happen. You'll see this done in every wakeboard tournament where they position the bodies so that the wake is even on both sides. It's not a speed or TAPS issue, although they will also affect the wash level of the wake, but usually it's both sides.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostYou need to balance your boat side-to-side. This may mean moving people around to make that happen. You'll see this done in every wakeboard tournament where they position the bodies so that the wake is even on both sides. It's not a speed or TAPS issue, although they will also affect the wash level of the wake, but usually it's both sides.
My right side can be terrible if I run TAPS at 8 but looks great at TAPS 3-6 depending upon how much weight I have in the boat.
If you have ballast add weight to the starboard side only. Or have some of the people move to the starboard side. That will help the wake not to wash out and also will add height to it.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by da.bell View PostHowever, you can't rule out this yet. I think we need more information.
My right side can be terrible if I run TAPS at 8 but looks great at TAPS 3-6 depending upon how much weight I have in the boat.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
My right side can be terrible if I run TAPS at 8 but looks great at TAPS 3-6 depending upon how much weight I have in the boat.Work because I have to eat, ski because I have to live!
TAPs does not adjust the size of the wake per Chpthrill's experience. I say it does a little bit but each person has a different opinion just like Tige has their opinion on TAPS.
IMO, don't run TAPS at 8. I have never had a good wake at TAPS 8 because the lip was too much.
Adding more ballast to one side of the boat isn't any different than having the people move around in the boat. The only difference is that you don't have to have your friends move now.
Originally posted by onevalkyrie View PostThis seems to be the same thing that I'm experiencing on the taps. Our thoughts at the beginning were the higher the TAPS the bigger the wake, but it seems that all the TAPS does is shape or clean up the wake. I don't really see any change in the size of the wake. We haven't really worked at moving people around except to level things out. When you talk about weighting down one side only it seems to me that the boat would be running through the water listing to whichever side??
As far as weighting, front to back, the rule of thumb is at least 50/50, although I go closer to 60/40, front/back. Remember, you have to compensate for the V-Drive's engine being in the rear.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by da.bell View PostIMO, don't run TAPS at 8. I have never had a good wake at TAPS 8 because the lip was too much.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Hey guys thanks for all the input its beginning to sound like we just need to learn more about what the heck we're doing. Last year this wasn't an issue but this year I find myself surrounded by experts since they can ski further that 50 feet without falling. HA HA HAWork because I have to eat, ski because I have to live!
Originally posted by dogbert View PostHey, you get a couple of fat buddies like ragboy and me in your bow and you'll be singin' a different tune
Originally posted by da.bell View PostI am sure it could be done but I can't afford two boat payments and then two plane tickets each and every time that I need you and Rag's help.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
