I was out on the lake sunday after noon when I ran into problems
The boat was running and I had just come off plane from surfing. Went to put the boat back in gear to pull a rider up and all it would do was idle....
I could peg the throttle and it would just idle. at the same time I noticed the volt gauge was at 10....
So of course I called chp. I checked and its not the throttle cable or the linkage because its moving at the throttle body. other than that I havent had a chance to check it because of school.
Im thinking the alternator went bad and hopefully just put the boat into limp mode
any other ideas?
