My second is in the port locker with the amps also. My third is in the starboard storage with the sub enclosure. I ran 0ga around the bow and to it...ouch$$!! I had weight/balance issues with out moving the second battery. I'm still a little light on the SB side, but that helped little.
Second Battery for Stereo???
Originally posted by signguy22 View PostSo....I hooked up a battery charger and charged the second battery back up and tried the stereo....and now they still won't turn on. After testing with a test light I found that the REMOTE turn on was not working...anyone know what would cause this, or how to fix it?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by signguy22 View PostI only checked it at the amps. Why? Should I check it at the HU too?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by signguy22 View PostThanks, I know that is where the signal comes from, but if it isn't at the amps then it probably isn't coming from the HU...Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
